跳转到主内容
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
How to remove and replace the heater fan
How do I replace the heater fan motor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  • Disconnect Battery: Unhook the negative battery cable.
  • Remove Glove Box: Unscrew and take out the glove box.
  • Access Blower Motor: Remove any covers or panels blocking the motor.
  • Replace Motor: Unplug the old motor, remove it, and install the new one.
  • Reassemble: Put everything back together and reconnect the battery.
  • Test: Turn on the vehicle to make sure the new motor works.
这个答案有帮助吗?
得分 0
1条评论:
It was my fault that it was wrong. I should have told you that the truck is a 4 door model , 4 wheel drive, V8 motor. It is different than the two door truck.
完成的
添加一条评论
添加你的答案
Ronald Brake Trotter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 145
