跳转到主内容
Google Pixel 5智能手机的维修指南和文档。发布日期:2020年10月15日。型号:GD1YQ,GTT9Q。
Adhesive misaligned - Can it be adjusted?
Hey everyone, i could use some help - I recently replaced my battery with the iFixit kit and used the included screen adhesive, but I didn't realise until too late that I accidentally misaligned the adhesive on the bottom right corner, because everything else is firmly sealed, but that corner is slightly disconnected from the back piece. Is it possible to take the screen back off and realign it without more adhesive? Or will i need to replace all of the adhesive? Thank you for your help :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Brandon,
You could try to realign the adhesive, although in my experience, this rarely works.
You'll probably have to use new adhesive if you want an optimal seal. (Just remember to remove the old adhesive!)
Hope this helps, let me know if you have any other questions :)
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your help! I appreciate it :)
I looked online and found a good alternative adhesive, so I'm going to try again soon. Wish me luck!
完成的
添加一条评论
添加你的答案
Brandon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
