跳转到主内容
Announced 2020, August 05 Status Available. Released 2020, August 21
43 个问题 查看全部
How to clean the usb-c port on my mobile phone?
I have problems with the usb.c port of my mobile phone (note 20 ultra 5g), most likely dust. I have seen that one could use a spri on a wooden toothpick (like Stickum), but my doubt is: after using it inside the usb-c port, it will be sticky and then it will be worse. Alternatively, can you list other Stickum-type products that do the same thing but do not damage the mobile phone? Lária compressed I think worse would be a mini but strong hoover as an alternative Other ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @helen40974
Safest option so as to not cause any damage to the USB-C port would be to get an air duster can (examples only) and use it to blow any dust/debris out of the port.
这个答案有帮助吗?
得分 1
2条评论:
@jayeff
do you think a can of compressed air or a mini hoover is better? Yesterday I was looking for a hoover (for the house) that doesn't cost much 50/60 euro what do you think? do you have any none/brand to recommend very powerful
完成的
@helen40974
You could try an ordinary vacuum cleaner, just don't use it for long periods at one time.
If you haven't got a vacuum cleaner and you can also use it for normal vacuuming, then buy one that suits.
If you don't need a vacuum cleaner then buy a can of air. It is more convenient and you don't have to use it all at once, just in case you need to clean the port more often. This may occur if you use the phone a lot in dusty environments etc.
完成的
添加一条评论
添加你的答案
Helen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 19
总计 19
