110.65132411 No power, not fuses, working door switch
My 110.65132411 dryer just sopped working the other day no power no inside light. It has blown the heating element before so i took off the back checked everything
all fuses are good and tried bypassing them to be sure
thermostat is good even swapped in a extra, power does get to it
it does have power to the start switch and it does function. no voltage drop when pressing start
The door switch does work
the timer looked burned maybe so i replaced it
there are no circuit boards other than the moisture sensor but i only use timed dry so wouldn’t think that matters. the unit was 500 and that board is over 200 so not going to replace that
After checking all that no difference no loose connections. there looks to be power getting everywhere but the inside light but seams to have no power,
