跳转到主内容
加入维修社区 - 创建账户
The Lenovo ThinkPad X1 Carbon 8th Gen comprehensive repair guide is designed for students, professionals, and technicians. It provides detailed steps for troubleshooting and efficient problem-solving.
How I can change ram
i want to replace ram
and want to upgrade 8 gb to 16 gb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @adnanhassan
The memory is hard mounted on the systemboard and cannot be replaced.
To upgrade the amount of memory you would have to replace the systemboard.
Here's the hardware maintenance manual for the laptop. Go to p.86 to view the procedure to remove/replace the systemboard.
Here's the parts lists for the MT 20U9 and 20UA models, that may help. (check for the MT number on the product information label on the bottom of the laptop).
Click on Select Commodity - System Boards (110) to find the part numbers for the 110 different systemboards that are used in the laptop. If you click on the Specs link in each part you'll see the relevant specifications of the motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adnan Hassan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 89
总计 1,640
