跳转到主内容
加入维修社区 - 创建账户
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
How thick are the speakers?
Hola, I want to put better speakers in my own laptop because they sound rather meh and knowing how Macbooks sound, getting their replacement parts sounds like the best choice. Does anyone know how thick they are so that I know if I can fit them inside?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The internal speakers are specially designed to work with this model—they have a unique shape, unique cables, and unique connectors on the main logic board. I don't know of any third party internal speakers that would be compatible with this device. If your speakers sound blown or damaged, you could replace them with good condition speakers, but if you want longer-lasting better quality speakers, I would recommend using an external Bluetooth speaker. Good luck!
Edit: Here's a picture of the 16-inch 2019 MBP speaker with dimensions.
这个答案有帮助吗?
得分 2
5条评论:
I am a tinkerer. Let me rephrase: I have a non macbook laptop with Windows whose internal speakers I want to upgrade, and since speakers are all the same thing (a voice coil with a magnet) I will find a way to drive them even with their specific connections. The only info I need is the dimensions of them, specifically the thickness they have, so that I can know if I can order them and make this project a thing. Thanks!
完成的
OK I think I understand now. Just a heads up, in the future it might be a good idea to choose a more generic device when posting your question rather than the MacBook Pro 16" 2019, because I thought this was a question about replacing the speakers on that model. The different models of MacBooks have differently designed speakers with different heights and widths, so there is no one answer for your question. If you're curious about the dimensions of the speakers for a specific model, I may be able to figure that out for you if you specify the model.
完成的
Alright, I'll remember that. The choices I have that look like they'd fit are A2992, A2918, A2141 and maybe the A2251. If you have one of those by any chance to extract dimensions from, I'd be more than happy.
完成的
I edited the original answer to have a picture showing the dimensions for the 2019 16-inch MBP.
完成的
Thanks alot! You're a great help.
完成的
添加一条评论
添加你的答案
Littlebigbottle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 142
