Where is the thermostat sensor on Chevy Colorado 2017
Where is the thermostat sensor located on a 2017 Chevy Colorado
In the 2017 Chevy Colorado, the thermostat sensor is located near the thermostat housing, which is typically on the engine block or cylinder head, connected to the upper radiator hose.
这个答案有帮助吗?
There is no such thing, thermostate is a passive actuator which only works when coolant temperature change, opens when coolant temp goes up and closes when it drops.
It does not need and electric power supply and will not provide any signal to computer, it just works passively.
I assume you mean coolant temp sensor? Or just trying to find thermostate itself?
这个答案有帮助吗?
Indeed you are correct as to I meant the coolant temperature sensor, Please and Thank you.
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 18
总计 18
