跳转到主内容
加入维修社区 - 创建账户
Apple 第六代 12.9 英寸 iPad Pro 的维修指南和拆卸信息。2022 年 10 月 18 日发布。
possible switch from usb to lightning
can I swap out the USBC port with a lightning port for my iPad Pro 12.9 6th gen
I have had to replace it twice for shorting out and never had to replace the lightning port in my older model
if possible what should I order
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I don’t think that’s possible as the physical connector is not the same between the USB-C and lightning port as well as the protocols running within the connector is very different.
The physical USB-C interface is what Apple used with its ThunderBolt-3/USB-C-4 interfaces. Different models still use different parts as Apple loves changing things under the hood.
While this won’t fix the damaged USB-C port on you iPad. This might offer a way to minimize the damage Apple USB-C to Lightning Adapter
Are you working in dusty/wet areas?you might want to get a USC-C silicone port plug to protect the iPads port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mark miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 190
