跳转到主内容
What part contains the mic?
Need to replace my microphone but I don’t see it listed anywhere. What part includes the mic?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You are going to have to be more specific; there are three microphones on the iPhone 12 Pro model, depending on what you're doing.
The one primarily used on phone calls is located at the bottom of the phone and is mounted on the charging port assembly.
A second microphone is used when you're on speakerphone or using the selfie camera and is located on the earpiece speaker assembly mounted on the display.
The third one is on the rear side of the phone in the middle of the cameras, and is mounted on the flash assembly.
In each of these images the microphone can be seen as a small gold-colored rectangle.
You should be aware that replacing the earpiece speaker assembly will cause you to lose Face ID. There should be no issue replacing any of the other microphones.
Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627.图片
产品
iPhone 12/12 Pro Lightning Connector Assembly
$26.99
Fix a malfunctioning flash with this replacement assembly.图片
产品
iPhone 12 Pro Flash Cable
$29.99
Replace an earpiece speaker or sensor assembly compatible with the iPhone 12 and 12 Pro models A2172, A2402, A2403, A2404, A2341, A2406, A2407, A2408.图片
产品
iPhone 12/12 Pro Earpiece Speaker and Sensor Assembly
$32.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
chevroleddie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 139
总计 1,282
