How to fix square button?
The square button when pressed is stuck and feels awkward. Feels like a controller with a sticky button. I tried alcohol and blowing it. need Help!
You can find a repair part to fix the PS Vita square,cross,round, triangle, start or select button here :
http://www.consolereparatie.eu/contents/...
Verry easy to fix it yourself, you can use the PS Vita teardown guide found on here :
这个答案有帮助吗?
i can only suggest calling sony it is still in warrenty and this issue will be covered because its not your fault. you can take it apart but there arent many spare parts knocking around so i would just call them they should replace it
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 4,809
2条评论
has anything been spilt down it or is it the mechanics of the button?
由 daniel robinson 完成的
@ daniel robinson It is the mechanics of the button
由 joseph floyd 完成的
