跳转到主内容
Repair and disassembly information for Samsung's Galaxy A32 5G Android smartphone, released in February of 2021.
Why is my phone stuck in an eternal loop of restarting?
My phone was lagging so decided to try restarting my phone, but I pushed the restart button and nothing happened. I pushed it a few more times then pushed the power off button. Immediately the phone restarted and when it finished, it restarted again. It restarted over and over again for about 2-3 hours before it stopped (probably because it ran out of battery) and holding the power button would just make the screen slowly flash black. when I plugged it in, it turned on again but it just starts the eternal loop of restarting again.
also every time it restarts it flashes some text that I can't quite make out.
this is the sharpest I could get it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hey hi Benjamin, your stuck on a boot loop. Go to the given link, read the solution and try to do it: SOLVED: My phone is fully charged but not turning on it is only showing up it' - Xiaomi Mi 2 - iFixit
这个答案有帮助吗?
得分 1
2条评论:
I tried doing the soft reset and entering recovery mode using instructions specifically for the samsung, but recovery mode would not work and the soft reset seemed to work at first, but then the text flashed again and it restarted.
完成的
@benjamin7425 can you please try to make the image more clear so that it is understandable for me and then I can further investigate on the problem. Also sorry for the late reply Benjamin!! Sincere apologies for the late reply. Please its a kind request to get a more clear image of the text that is getting flashed after every restart or so.
完成的
添加一条评论
添加你的答案
Benjamin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 32
总计 335
