跳转到主内容
加入维修社区 - 创建账户
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
Water on power button
So I was on my pc and without me realizing some water dripped onto my power button and now my pc keeps turning itself off every few minutes, I tried drying it off and unplugging the connection and putting it back in but it still does it. After turning off it won’t let me turn it back on for a few minutes as well. Anyone know how I can fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @odst15ethan,
What is the make and model number of the motherboard and the PC case that it is mounted in?
完成的
An easy way to isolate it would be to try powering the pc on without the connector the button and any pcb there might be for the button. This is a bit difficult without knowing what board it is and what pins do what. Providing the information requested by @jayeff would help us giving you a better answer.
完成的
添加一条评论
1个答案
does your PC have water cooling? Maybe the water is on other places. OR maybe the cooler isn't working now and the PC is turning off because the CPU is overheating.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
odst15ethan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 87
