跳转到主内容
The truck has a new exterior profile taking styling cues from the 2014 model year 4Runner SUV and the 2014 model year Tundra pickup and features a much more aggressive and masculine look, with a larger grill and new projector beam headlamps.
5 个问题 查看全部
Pressing gas and brake simultaneously warning light
Once in awhile a warning light comes on with a foot and pedal on it, when I accelerate. When the light is on the truck seems to be in limp mode, and will not go over 5 miles or so. What is causing this? how do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @luthermanriquez
The warning light indicates brake override malfunction.
You're not the only one to have experienced this problem. Here's a link that describes what others have tried and found (or failed to find) caused the problem.
Since your problem is intermittent it may be more difficult to isolate but perhaps first check if the 10A Stop fuse #28 in the engine bay fuse box is OK. Also check that the taillights are all working OK and not that one is dimmer than the rest, as these two things seem to have some affect whether it occurs or not.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luther Manriquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 16
