跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
786 个问题 查看全部
Installling ifixit battery is causing high cpu by configd
I have recently replaced original battery on my old macbook pro with ifixit battery (MacBook Pro 15" Retina (Mid 2015) Battery), and I have noticed that when the laptop is on battery power, configd is causing high cpu utilization, typically greater than 100%, which also increases fan (you hear fan going crazy), see the spinning rainbow, and the laptop stops responding to any keyboard or mouse input.
When you attach power cable, then it goes back to normal.
I searched online, and there was a post suggesting turning internet sharing off. It was never on on my laptop to begin with. I am not sure how to go about fixing the issue. The whole reason to buy and install replacement battery is to use it without always tethered to power cable, but configd's high cpu utilization is preventing it.
Has anyone encountered such issue? How did you fix it? Does ifixit have solution? Any help or suggestion would be much appreciated.
MacBook Pro 15" Retina (Mid 2015) Battery图片
产品
$109.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Seems like it's an issue with certain third party batteries. Might be worth exploring this Reddit thread if you haven't already—there are a number of people with the same issue there. Might be worth contacting iFixit directly to see if they have a recommendation or can send you a replacement battery to try. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
crackle-typos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 9
