跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Start computer without power button
I have the power button not working and the options starting computer with opening the lid or pluging the charger are disabled on nvram.
I ve read about a solution to unplug yhe battery and then plug in the charger and the computer will run.
Will this work or damage the mother board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
All macs since 15 years autostart if you plug valid power supply with if no battery is present.
by valid i mean the one with enough power rating, in your case 60W or more.
this will not damage the motherboard. you can unplug battery flex cable, plug power supply and carefully plug battery back in. however, Trackpad / Lid Power trigger should work unless there is some other issue with the device.
这个答案有帮助吗?
得分 0
5条评论:
So the laptop should start after i plug the power supply or after i plug battery back in?
完成的
@chihabeddi53934 - Almost! There are two provisos here. The first is first fully discharging the logc board by disconnecting the battery and charger, then press and hold the power button a good 15secs. The second is plugging in the charger not the battery as it won’t likely have enough power.
完成的
The power button is already not working so i cant try any procedure including a power button step!.
The method of disconnecting the battery is good, but i dont know if the computer will turn on after the 2nd step ( steps mentionned above ) or after the 3rd .
All this is to turn on the computer and set nvram settings to default ( starts on opening the lid)
Thanks for your time
完成的
@chihabeddi53934 - To be clear it’s SMC not NVRAM that is related to the power aspects and how TouchID controls access. It sounds like the button is physically broken or not the mated one to the systems logic board.
完成的
I changed the setting by typing in the termina " sudo nvram autoboot =%00"
The fingerpring scan is working but the button is not hence my problem.
完成的
添加一条评论
添加你的答案
Chihab eddine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 59
总计 332
