跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1148 个问题 查看全部
How to fix iPhone screen if it looks like a negative print?
My iPhone fell from my hands. When I picked it up, the screen lost the real colors. It looks like a negative print photo!
What can I do to fix my iPhone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 98
38条评论
I have this problem on a 3g iphone, so its nothing to do with the accessibility function found only on 3gs.
If I press top right corner of display image flips upside down.
I don't believe water damage is the culprit, any other ideas?
完成的
Hi my iPhone 5s is having the same negative problem. I have tried all the fixes suggested here but nothing is working. It wasn't dropped. I did up grade to Yosemite earlier today though on my laptop. Could this be the reason?
Please help
完成的
I just downloaded Yosemite but clicking the home button 3 times doesnt work any other suggestion
When i turn it off in accessibility it will ask me Are you sure you want to disable inverted colors. then when I say ok it stays the same Not sure what to do.
完成的
I have the iphone 5s. It had the same negative problem. I have tried the home button 3 times, as well as the Settings-General-Accessibility-INvert Colors. When I turn the invert colors it just makes the screens black and white, but no color. Grrr.
I don't have any white on black option, either. Just an invert colors and grayscale. The grayscale doesn't seem to do anything.
Can anyone help?
完成的
Erica I had exactly the same problem.My screen turned negative in my pocket. After reading all the Q&A online on how to fix it everybody was talking about how to go to Accessibility and turn "invert colour" botton on or off. I did the following : General/Accesibility/Interaction/Accesibility Shortcut and tick Grayscale and Invert colours. By doing this you will make sure that you will be able to access those two functions with your home button when you press it 3times. So what I did, I changed my screen from negative to black and white by turning "Invert colour" button on only and then from the locked screen I triple clicked the home button and ticked Grayscale. My phone had the colours restored. Thank god. Hope this helps :)
完成的
显示更多的33条评论
添加一条评论
26个答案
已选择的解决方案
Try clicking the Home button 3 times (really fast). If that doesn't fix it, go to Settings/General/Accessibility/Triple-click Home, and select the "White on Black" option. Then, triple-click the Home button.
这个答案有帮助吗?
得分 81
74条评论:
Wow! I just tried clicking the home button three times like you said and instantly my negative images turned positive! Thank u thank u thank u for your awesome help! I wonder if it might work for my checking account!? :)
完成的
Thanks for the tip. Even my I phone fell down twice and after I triple clicked and chose the black and white option.. to my surprise, within a second, my phone turned normal. Great..
完成的
thank you!!! It worked!!
完成的
wow u da best!!!
完成的
Wow! How awesome! So quick and easy! THANK YOU!!!!!!!!
完成的
显示更多的69条评论
添加一条评论
I had same problem with my 5s, turned blk and wht, tap screen 3 times with 3 fingers, go into choose filter then tick none, job done!
这个答案有帮助吗?
得分 22
10条评论:
At last I got the answer.. thank you very much
完成的
Brilliant - got the job done! Thanks
完成的
Yay! This worked. Thank you!
完成的
Thank you, Paul! How on Earth was the average shmo like me supposed to know that??? :D
完成的
thank you , i had a headache ,
完成的
显示更多的5条评论
添加一条评论
Don't bang on anything. Go to setting on main screen. Click on General, scroll down to Accessibility, click. On the next screen make sure invert colors is turned (OFF) This is for the Apple 4S Iphone
这个答案有帮助吗?
得分 15
5条评论:
Wow this worked! Thanks!
Now what caused the screen to turn negative. I did not drop it or anything. I had it in my pocket and when I pulled it out, it had the negative screen.
完成的
Mine was in my back pocket also so all I can figure is that since pressing the home button 3 times makes it go negative also it must have happened while it was in my pocket. Thanks for the help.
完成的
OK. I was stumped. I found this page. The triple click on the home button did nothing for my 5S. But the Settings/General/accesibility/INVERT COLORS-ON worked immediately. THANKS
完成的
by brian thanks i've been trying all night to find a way to fix this problem on my iphone 4 settings/general/accesibility/ and most important [ =====INVERT COLOR ====] worked rite away thank-you . PS i thought the camera was shot for good
完成的
I did it it dosent work
完成的
添加一条评论
Experienced same problem on iPhone 3 GS with iOS5 just installed. Triple clicking home button dod not work. Solved problem settings/general/accessibility/ turn off 'white on black' (no idea how it self selected).
IOS 5 working fine, no problem downloading (8 min via my Macbook)) now launch day bottleneck over.
这个答案有帮助吗?
得分 4
11条评论:
Thank you for the help, i am computer illiterate and i found this to be a fix i even understood. gen/settings/access/ turn off Black/White. i aslo do not know how it selected this mode originally.
完成的
Thank you. Went back to the settings, as suggested. I guess I must have accidentally pressed a certain sequence and let the negative image loose! Merci from Montreal.
完成的
thank you so much, my mum would've killed me if i didn't fix it, cause it was hers not mine!
thank you!
完成的
Thank you
Worked easily !
完成的
Great: also on a 4G three times home made it all positive again. I wasted more than an hour trying to find a menu option to do the same, I google 10 seconds and have solved the problem!
完成的
显示更多的6条评论
添加一条评论
I have press 3 time of home button but it I have press 3 time of home button but it doesn't work on the other hand my iPhone 3G ios 4.2.1 has no accessibility option so how can I fix it please tell me
这个答案有帮助吗?
得分 3
1条评论:
Iphone5c cant get black and white off after all that. Turned off bold setting it said it was going to restart.omg now its really screwed up. Extreem big letters. Shut off again same
完成的
添加一条评论
I did the settings/general/assessability/invert colors trick on my 4. Thanks for the info.
这个答案有帮助吗?
得分 2
5条评论:
I have the same thing but on a iPhone 5c
完成的
Happened to my iphone 5c also. I had to turn off gray scale and invert colors. That worked.
完成的
thanks. Ali got it...
完成的
I have a lg phone
完成的
How do i fix my lg from looking like an exray
完成的
添加一条评论
Apple I-phone 5 S
I just down loaded the newest version of I-OS7. Phone screen went to inverted colors or looked like it was a negative. The first fix of tapping the Home screen three times did not work. I then went to 'Settings', then 'General', then 'Accessibility'. Once there there is a heading labeled vision. Look in that column for the Invert colors button. Its probably turned on. Tap it to turn it back to normal.
这个答案有帮助吗?
得分 2
2条评论:
Oj how can we just reset the phone?
完成的
Thank you so much
完成的
添加一条评论
My iphone 5 turned black and white. Went in to settings -accessibility- vision and undid the invert colours. So now it is even more black, like a neg.
Have read all your answers, but nothing works. When you say home button, do you mean the main button down on front? Thats where I click 3 times right? So have accessed _accessibility-from there to. Still doesnt work....So in anyway, also did restart it of course.
Update
so I had to reset it. so now I have colours!!!
这个答案有帮助吗?
得分 2
2条评论:
I have a 5c , tried everything suggested - read the above post and RESET . I have color now . Easy and less time wasting option ..thank you.
完成的
Ty im a phone moron n i tried all night, ty for yer time
完成的
添加一条评论
I panicked to my iPhone 4s went black and white tapped 3 times back on oh what a relief
Thanks heaps and heaps.
这个答案有帮助吗?
得分 1
添加一条评论
ipad pressed button 3 times now perfect
这个答案有帮助吗?
得分 1
添加一条评论
Yeah this helped a great deal Patricia
这个答案有帮助吗?
得分 1
添加一条评论
I think that i leaned back and so was my iphone 4s behind me. Now the colors on my screen are completely messed up. I dont know what to do. I tried to call my friend. It worked. Then i tried to text my friend. It worked. Then i tried to turn it off and on. IT DID NOT WORKED!
这个答案有帮助吗?
得分 1
添加一条评论
I have an IPhone 4 and unfortunately nothing is working for me either
这个答案有帮助吗?
得分 1
添加一条评论
Go to Settings, General, Accessibility, Turn ZOOM OFF.
这个答案有帮助吗?
得分 1
添加一条评论
I'm having the same issues right now with my iphone 4. I have done all of the above solutions but it's not working. I have tried the invert, the triple home button and also the turn off zoom. Soft reset is also not working. Please help. Is there any way I can fix it without having to buy a replacement screen?
这个答案有帮助吗?
得分 1
添加一条评论
I can't see anything on my screen but it responds to my touch. I didn't drop it or anything but it just turned into lines. Please help meeeeee
这个答案有帮助吗?
得分 1
2条评论:
i have the same problem please help!!!!!!!
完成的
my screen is white and cant even see rest of it
完成的
添加一条评论
Hello , I have an IPhone 6s and had a problem where the screen looked as if it had an orange filter on it. If anyone has this issue Settings>Display and Brightness>Night Shift>Then switch color temp to the lowest setting! Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Thank you for your help
这个答案有帮助吗?
得分 0
添加一条评论
Hit the center button for apple ipad 3 times or center button it will change the mode from color mode to ex ray mode
这个答案有帮助吗?
得分 0
1条评论:
Holy cow! Worked for my iPod! Triple click woowho.
完成的
添加一条评论
My Iphone 4 screen randomly flickers at the bottom and then the colours go all weird but EVERYONE is putting the same answer
...Triple click home or go to accessibility and make sure inverted colours is not selected, I have done this a good amount of times now to realise this is not what is wrong, so I am asking please if there anyone out there who has gone through what I am going through or has any idea what is wrong..Please help me.
这个答案有帮助吗?
得分 0
1条评论:
Mine is an Ipod touch 4 and I have the same problem I think. It looks like a photo negative, but parts cannot be seen to read. I also tried the fix mentioned here without success. I was told to replace the digitizer. I have not done so yet, but would accept a confirmation on this.
完成的
添加一条评论
Hello i hope that someone can help me ... Recently I have bought an iPhone 4s but after a while I had that problem that the screen looked like invert colours was on but only if i viewed it from a angle or on dark images/videos. Is there a way to fix it without having to buy a new screen ?
这个答案有帮助吗?
得分 0
添加一条评论
None of the above written aswers are working on my Iphone 4s. What can I do?
这个答案有帮助吗?
得分 0
1条评论:
Go to General in Settings, Accessibility, Turn ZOOM OFF.
完成的
添加一条评论
i took my iphone 4 apart and put a different screen on it but it didnt work so i put my old one back on it and it now has all neon colors and has black ink spots and i dont know why
这个答案有帮助吗?
得分 0
添加一条评论
So I have iPhone 5c and I had same negitive issue after playing in settings for a while and I went to Settings/General/Accessibility and then turned OFF Gray Scale and that worked for me. :) Ughhhh!! That took forever though!! Not fun at all!! Ughhh!! So glad that's over and so happy to finallyyyy have some color up in here again!!! Just sayin!!
这个答案有帮助吗?
得分 0
添加一条评论
Same prob with 5c and did all the above in various sequences and finally got color back but don't know exactly how I did it....But thanks to all for the help.
这个答案有帮助吗?
得分 0
1条评论:
I already tried all of the suggestions, but nothing happen to my iphone7, somebody could help?
完成的
添加一条评论
I have the same problem with everything looking like a negative, but I have the iPhone 11 Pro Max?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
massiel 将永远感激不已
浏览统计数据:
过去 24 小时: 22
过去 7 天: 150
过去 30 天: 678
总计 607,888
