Have you checked the brake fluid level in the brake master cylinder is OK and that there are no leaks in the brake lines or around the slave cylinders near the brakes?
Make sure you bleed the brakes to make sure 100% there is no air in the brake system. You may also need to replace your brake fluid. Make sure there are no cracked or missing vacuum lines.
Hi @ethan2706,
What is the year and F-model of your vehicle?
由 jayeff 完成的
