跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
330 个问题 查看全部
Trackpad and keyboard not working after installing battery on 2017 Mac
I installed a new battery in my 2017 15.4" Macbook Pro and now the trackpad and keyboard don't work. I can use a bluetooth for the keyboard but the bluetooth mouse does not track.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Mmm… Two unrelated issues!
The internal keyboard and trackpad connect to the logic board independently, both connections are near each other. So you’ll need to inspect the connections for damage or the cables will need replacement. Reference this marked up image, I’ve marked the two connections
As far as your Bluetooth mouse, that’s clearly a mouse issue. Double check to make sure it’s being recognized within the Bluetooth settings, it’s also possible the mouse is having a sensor issue if it is responding at all.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ronee K Finch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 17
