跳转到主内容
How to fix the seventh generation of Honda's compact car.
74 个问题 查看全部
2005 Honda Civic Lx 1.7L check engine light blinking
2005 Honda Civic Lx 1.7L check engine light blinking running rough/ shaking at idle or at a stop ive already replaced all 4 of the coil packs, the spark plugs and the injectors as well as both o2 sensors and the exhaust manifold/ catalytic converter.
I'm stumped and need to get this figured out and fixed ASAP as it's my only vehicle
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @kennyhorner
The quickest way to know what's wrong is to get the vehicle's OBDII port scanned and check what DTC codes have been logged.
If there is a code (or codes) it will tell you what the problem is.
Major auto parts retail stores in the USA e.g. AutoZone will do this for free apparently.
这个答案有帮助吗?
得分 0
2条评论:
I've already took it to advance auto and all the codes that show up are for misfire in all 4 cylinders and both O2 sensors which I just replaced both O2 sensors as well as all 4 of the spark plugs and all 4 of the coil packs
完成的
@kennyhorne52702
Have you checked the harness connections on the ECM module (under/behind dash, passenger side)?
完成的
添加一条评论
添加你的答案
Kenny Horner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 23
