跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Home button is not working
I dropped my iPhone 3G after 3 years of (hard) use, this cracked the glass. I then got a new 3GS, and used the old 3G as an alarm clock. One night I reached out for a glass of water and knocked it over. The next morning the 3G was making crackling noises, so I dried it out but she was dead, Jim.
So it lay on my desk for some months. Then I decided I would fix it. I got the new front cover and glass, (no home button) and also new docking electronics. Replacing these went smooth as advertised.
So when I charged it and switched it on, I was happy to see that everything seemed ot be working....except the home button. Nothing. Press hard, sideways, up down, nothing nothing nothing.
So I said some words, ordered ANOTHER front screen assembly this time with the new home button and plastic and stuff. Installed it no problem, but....exactly the same problem. Home button she dead, dead, dead.
Any help, much appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Seems to me as though the Logic Board has suffered corrosion via liquid damage. The annoying thing about liquid damage is that sometimes it will completely destroy a phone, and sometimes it won't. However you also have the chance of the iPhone working perfectly fine, bar one functionality.
I have personally seen this a few times and yes, it does suck, however if you have already replaced the dock connector and the digitiser yet still no luck, then the logic board has probably been damaged and you will need to replace the entire unit. :(
Hope this helps,
Martin
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
piet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 612
