跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
266 个问题 查看全部
Possible to upgrade logic board - A1707
I have a 2016 MBP, touchbar and I'm curious if it's possible to upgrade the logic board? I know that basically all the components are soldered into the board, so that's out.
But what about the logic board itself? Could I take a board from, say a 2019 or other year and install that?
Are they even close to the same dimensions/connectivity? Is there a good way to measure
This is probably going to be a solid no, but I'm just musing. Given that my laptop is now 3 OS upgrades behind, I'm wanting to do what I can to keep it running
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Well… jumping to a 2018/2019 is not possible as the logic board is very different. But you could swap out the logic board with a better 2016 CPU/GPU setup and/or higher RAM or storage.
Now the bummer! In most cases most people just jump to a new system used or new as it’s less risky and transferring your stuff over is a breeze!
这个答案有帮助吗?
得分 1
2条评论:
This is pretty much what I was thinking, thanks for the confirmation! It's one of those things that "seems" like it would logically work, right? They're all mostly the same size, so you should be able to swap in a different board....I'm guessing Apple thought of that and made everything juuuust different enough.
Le sigh
完成的
@danking - It’s not just Apple, ultra thin laptops in general don’t offer logic board swap outs. A traditional Desktop tower PC does offer that to some degree.
Sorry for the bad news, in any case if you’re set don’t forget to accept the answer. Thanks!
完成的
添加一条评论
Just sell it and use the money you would spend on just a logic board and the hassle and risks of damaging something swapping everything over might actually cost more in the long run. Or use opencore patcher to upgrade to Ventura or Sonoma if it is that important.
https://github.com/dortania/OpenCore-Leg...
这个答案有帮助吗?
得分 1
2条评论:
Part of the reasoning for my question was that I tried out OpenCore Legacy and it worked - as far as installing Sonoma and then Sequoia on the system. But, WiFI and graphics were a bust. I'm sure performance took a nose dive too
完成的
@danking I personally will stick with Monterey, it is more friendly and supported by my unit (2015 MBP 15"). Opencore I never actually tried it, mixed reports, mostly issues with bluetooth and wifi as newer machines I think have upgraded cards for that which our older systems don't have.
完成的
添加一条评论
添加你的答案
dan king 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 31
