跳转到主内容
加入维修社区 - 创建账户
Apple 2022 年的顶级旗舰机型。iPhone 14 Pro Max 于 9 月 16 日发售,配备 6.7 英寸 ProMotion OLED 屏幕、全新的 A16 仿生芯片、后置三摄系统并支持 5G 网络。它是 iPhone 13 Pro Max 的继任者。
Are copper wires required for button function?
The flex cable (connecting the power button with the volume up and down buttons) that is also connected to the wireless charging coil has been severed. Upon attempted replacement of said flex cable, I discovered that the existing severed flex cable is connected to small copper wires attached to the wireless charging coil. If I sever those wires and just replace the flex cable, will the buttons be operational? Note: I can do without wireless charging as long as I can still charge the phone via the charging port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
For the circuit to work the connection is required. If you are asking about the wireless charging coil it won’t work if severed.
这个答案有帮助吗?
得分 0
1条评论:
I just need to know if the buttons will work again. Not concerned about the wireless charging.
完成的
添加一条评论
添加你的答案
Dawn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 230
