Need some help on trace pads ipad 5th gen Charging port
What pads need to be fixed?
Luckily, most of the pulled pads are ground. Only one you actually have to fix.
It looks like there is a bit of the trace let here to tack on to. But there's also a test point in the area where the orange circle is. You'll have to peel up the sticker to see it. The test point is between the two rows of points. You can't almost see it in the picture through the tape.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 25
@flannelist Hello can u help me with this?
由 stacksz bandz 完成的
@stackszbandz Let me check what I got. :)
由 Alisha C 完成的
