跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
No Power For Syscon Check
I recently picked up a PS3 Phat (CECHA01) with the YLOD. It has the COK-001 board. It had never been opened or serviced until now. I disassembled it and connected the UART to it to read the syscon errors. When I flip the switch on the power supply, I'm not getting any standby power (no red light on the control board). I confirmed the power supply is providing 5v to the board via the small 5 pin white cable. I also checked all the fuses (F6001, F6301, F6302, F6303, F6304) and they are good.
I currently only have the bare main board connected to the power supply via the white cable and the control board. Is anything else required to get the standby power on? All the syscon videos I've watched on YT are mixed. Some have it connected to just the white cable and other have it partially reassembled.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I found the issue. Connecting the DIAG wire to ground while in external mode on the UART will prevent access to standby power. Disconnecting the ground restored power and I was able to proceed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
at1105 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 380
