跳转到主内容
The Galaxy Tab S2 9.7 is a tablet released in 2016 by Samsung. This device comes in both 32GB and 64 GB variants. The Wi-Fi only model number is SM-T813. The factory unlocked 4G model number is SM-T819.
Sound buttons TAB S2 T819
Hi, Is it possible to change only the sound buttons blocked, i have yet open by the back cover (for changing battery) ? i don't want to dissasemble the screen too riskly. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jpg93500
You can't open it from the back cover. You need to remove the screen to get to all the internal components.
Here's the ifixit Samsung Galaxy Tab S2 9.7 repair guide, that shows what to do.
Once opened then you can replace the battery and also the volume buttons.
Do you mean the volume button actuator (example only) or the volume button flex (example only) which is the cable that has contacts on it which connects to the motherboard, that are operated by pressing the actuator button?
If the actuator then it comes in 3 colours, black, gold and white, to match whatever colour the tablet is. Just so that you're aware of this when trying to find a supplier. Search online for SM-T819 (insert required colour) volume control button.
If the volume flex, then it doesn't matter as it is applicable to the model, not the colour of the tablet ;-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
JPG93500 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 134
