跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
255 个问题 查看全部
Two components dropped from logic board, what are they for?
I have these two components dropped off from logic board when trying to upgrade blade SSD and ram, see pictures attached. Anyone knows what are they for? And will the logic board still work without having them soldered back? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Those are capacitors. Specifically 6.3 Volt 150 microfarad capacitors.
I won’t get in too much depth about their overall function (unless you want). But in this case your iMac probably will not turn on without them. It might. But I am rather doubtful. Not only does the schematic note them as “critical,” they are part of the circuit used to generate a specific voltage rail that is necessary for power on.
Sometimes capacitors can be left off, it depends on what their purpose in the circuit is. It won’t do any hard to try and boot it up without them, but I don’t expect you to get far.
Luckily, as far as components that could have popped off the board, these are big enough that soldering them back (or getting replacements soldered on) shouldn’t be too difficult with a little solder know how. It looks like they might have just had some brittle old solder joints that decided to give up the ghost during the repair. If the capacitors themselves don’t seem to be bulging, or damaged in any way, you can probably just solder them right back on without any harm.
这个答案有帮助吗?
得分 1
3条评论:
@Alisha Yeah, that is what I thought too. Do you know where I can buy the replacement for these two capacitors as the pins from each were broken too?
完成的
@lovecd The two major vendors I typically use for electronic components are digikey or mouser. Either would have something akin to what you need. I tried to snag the size from the schematic so I could get you a direct link, but no such luck.
These particular caps are aluminum polymer, but you can probably get away with another type if you need to as long as the specs are the same.
完成的
@flannelist, should I look for the one with the following specs?
Thanks,
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 31
