跳转到主内容
The HP Elitebook Folio 9480m was released on July 4, 2014. The 9480m model can be identified by model number J5P80UT.
How to change screen to my laptop?
screen change
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @itiplayz92
Here's the maintenance and service guide for the laptop.
Go to p.50 to view the procedure to remove/replace the display assembly. See Step.5 on p.51 for how to replace the LCD panel.
At the top of p.50 you will find the HP spare part numbers for the 2 LCD panels that can be used in the laptop.
Search online for the part number only of the LCD panel applicable to your particular laptop version, to find suppliers that suit you best. Usually the part number is located somewhere on the back of the LCD panel itself, if you wish to verify that you're getting the correct one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
itiplayz 92 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 119
