跳转到主内容
Removing screen from front bezel non-destructively
Hello,
I'm looking for a way to remove the screen from the bezel of an FZ-G1, I don't actually have the whole device, I just have the front bezel which has the webcam, screen, and front navigation buttons on it. I'm planning on using the display for a project as it has a wacom digitizer and a capacitive touch screen.
Would anyone happen to know of a way to separate the screen from the display without destroying it?
This might not be obvious from the image I posted, but the front surface is not flat as it is on modern devices, there is a bezel and the screen is visible through a cutout in the bezel.
Not sure if it helps but the FZ-G1 has an IP65 rating, so how ever they chose to bond the screen to the bezel must be pretty strong/durable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
the common way is to heat it with a blow dryer. The tape softens and allows removal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
coloneil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 434
