跳转到主内容
加入维修社区 - 创建账户
Repair, disassembly, and troubleshooting information for the 2nd generation Moto G Play, a Motorola smartphone released in 2023. Identified by model number XT2271.
Phone won't ask for unlock codes and TracFone said it's unlocked bwon'
My moto g is tied to TracFone. They say it's network unlocked but it doesn't work. I called Motorola they blamed TracFone and vise versa. Can anyone help? It don't ask for codes just says network locked sim
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Have you tried actually putting an activated SIM from another carrier in it? Sometimes (and I have seen this with TracFone specifically) it will say network locked in settings, but when you put a new SIM in it and reboot, it will give you the option to unlock it right then and there, just like "click here to unlock" simplicity.
这个答案有帮助吗?
得分 2
6条评论:
Yes I've put in my other sim that's a t mobile and it just says network lock. No option to put in a code. When I do put a code in it says network locked and that's it
完成的
I am unfamiliar with that specific model, but with the active T-Mobile sim, can you navigate to (something like, may not be exact) Settings > Connections > SIM settings?
Somewhere in there (or the equivalent on your specific device) there should something like "network lock". With another SIM in there, if it is user unlockable, there will be an option to select and you can turn it off (may need to connect to wifi).
If you don't find it exactly where you look the first time, look around more in connections/SIM/network settings. Click on many things and dig deeper into the settings. This menu is different place in many phones.
If there is no option, or it is greyed out/unselectable, or if you do find it and it says something like "access denied", then it is 100% a TracFone problem and they need to fix it, no matter how hard they try to blame Motorola.
完成的
No when I go to settings and mobile network it says can't use sim. That's with the working t mobile sim and so it's not reading anything on it...
完成的
But TracFone said it's unlocked. Motorola said it's unlocked and a TracFone issue and back and forth lol. It's a good phone I just can't unlock it
完成的
@donaldscholebo If that is how I'm thinking, it is definitely a lock applied by TracFone and only they can remove it. Sorry.
完成的
显示更多的1条评论
添加一条评论
Were do I put the iem number
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donald Scholebo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 452
