跳转到主内容
Repair guides and support information for Lenovo's IdeaCentre series of all-in-one desktops.
screen replacement for ideacentre aio 520-22icb
I have a lenovo ideacentre aio 520-22icb i ended up cracking the screen while trying to upgrade my ram but the problem i ram into is finding the touch screen for it so i could replace it do you guys have any ideas where i can find one for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @chrispoole12117
The display panel comes as a complete module assembly consisting of the LCD panel and the touchscreen panel i.e. not two separately removable/replaceable components.
Here's the hardware maintenance manual for the AIO.
Go to p.56 to view the procedure to remove/replace the LCD panel module.
Search online for 01AG987 (or 01AG923 - equivalent substitute panel) to find suppliers that suit you best. - (suppliers examples only)
这个答案有帮助吗?
得分 1
2条评论:
the removal part is not the issue its finding the replacement screen thats the problem i dont know where i can find one.
完成的
@chrispoole12117
There is no separate digitizer panel or at least the manufacturer doesn't list one. They only list 4 LCD panels for your AIO model i.e. 2 with touchscreens and 2 without
As shown above, search for the part numbers to find suppliers for the LCD+digitizer panel.
If there is a separately removable digitizer panel then check for the part number on the panel itself (if there is one) and then search for that.
完成的
添加一条评论
添加你的答案
Chris poole 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 191
