跳转到主内容
加入维修社区 - 创建账户
Released in July 2017 with 7th gen Intel processors.
Charging light blinking and not turning On
When i put charging plug in charging light blinks and not starting only blank screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I disconnecting the charger, then held the power button on the laptop for 30 seconds and release. Reconnect the charger and checked still not turning on
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @miteshcharoliya
Is it blinking continually or is there a pattern to the number of blinks e.g. 3 blinks > small pause > 3 blinks > pause etc.
A continually blinking power light is an indication that the laptop is in sleep mode.
Try either force stopping and shutting down the laptop by holding the Power button until it shuts down completely and then restart the laptop in the normal way
or
Try opening and closing the lid a few times and check if the laptop comes out of sleep mode by itself.
If still no good try to reset the BIOS to default in case there are any corrupted settings which may prevent the laptop from functioning correctly.
First try disconnecting the charger, if connected and then press and hold the power button on the laptop for 30 seconds and release. Reconnect the charger and check
If still no good open the laptop and disconnect the battery cable from the motherboard, press and hold the Power button for 30 seconds and then release the button. Reconnect the battery, reassemble the laptop, connect the charger and check that it initially charges OK.
Here's a link to the hardware maintenance manual for the laptop.
Scroll to p.37 to view the procedure on how to do this.
If it still won’t charge correctly then you have a motherboard problem
If it starts to charge allow it to charge fully before attempting to start the laptop.
If it starts OK allow it to boot all the way to the Windows desktop and allow the HDD activity to settle before checking things.
这个答案有帮助吗?
得分 1
1条评论:
I have the same type of laptop 320-15IKB its doing the 3 blinking lights pause and then another 3 blinking red lights while changing it does not turn on but it shows life by charging pleade helo
完成的
添加一条评论
添加你的答案
Mitesh Charoliya 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 91
总计 1,069
