跳转到主内容
Why is my computer running out of power So fast
When I'm done charging and then I left it tomorrow even though I Left it off it keep Running out of power help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @tingwang2013
Seems as though there's a problem with the battery in the laptop.
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as seen in the report.
For a good battery they should be nearly the same value.
You can work out the condition of the battery as a percentage by using the formula: Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery is <35% you may wish to consider replacing it.
Here's the hardware maintenance manual, for the laptop.
Go to p.70 and then to p.84 to view the procedure to remove/replace the battery in the laptop.
Here's the parts list for the laptop. Click on Select Commodity > Rechargeable batteries Internal(8) to find the spare part numbers for all the batteries that are compatible and can be used in the laptop (one of these numbers may also printed on your battery). Search online for the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
2条评论:
is at 56% so do i replace it or no?
完成的
@tingwang2013
You initial post was from 9 months ago so presumably the battery has been working reasonably well since then?
Try fully charging the battery i.e. 100% (check using the battery report that it is 100% or whatever it says when it stops charging) last thing before closing down for the night and then when you next start it see what charge % is shown.
It may be that the battery is self discharging too fast (a good battery shouldn't self discharge that fast, maybe only 1%-2% overnight)
If it loses a lot of charge overnight replace it as it isn't going to get any better, only worse.
完成的
添加一条评论
It could be because of your OS settings, if on Windows, check if your power plan has fast startup enabled and if you have been properly turning off the laptop.
If on Linux, check the same, but it could change where depending on your desktop environment,
这个答案有帮助吗?
得分 0
1条评论:
how is that Related to anything?
完成的
添加一条评论
添加你的答案
tingwang2013 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 114
