跳转到主内容
The Lenovo IdeaPad 330-15IGM is a slim and compact laptop.
2 个问题 查看全部
Battery for ideapad 330-151GM
I need a battery for the referenced lap top but can't seem to find one for it on your site. Do you have the proper battery for the 330-151GM
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @drose25585
Unfortunately, ifixit doesn't have a battery in stock that is compatible with your particular model.
Here's the hardware maintenance manual for the laptop.
Go to p.81 & p.81 Item #12 to view the part numbers (FRU number) for the 8 batteries that are compatible with your particular model.
Search online for the part number only, to find suppliers that suit you best. The battery model number e.g. L16M2PB1, L17M2PB7 etc, is printed on the battery in your laptop should you wish to verify that you're getting the same one (or a compatible one).
Go to p.36 to view the procedure to remove/replace the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Drose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 36
