跳转到主内容
蘋果2020年的主流 iPhone 機型,發布於10月23日,搭載6.1吋 OLED 螢幕及12MP 雙鏡頭模組,有著5種顏色。該機型為 iPhone 11的後繼產品。
Phone keeps going in to recovery mode
Hello,
I am having trouble getting my iPhone 12 to boot up. The screen is damaged with vertical lines and when turned on it goes straight to recovery mode. I have plugged in to iTunes and it successfully completes the restore, however once it is finishes with the cycle it still boots in to recovery mode instead of ios. I have connected to 3utools and tried the exit recovery mode option but it just boots back to it,
Also, the phone won't turn on when pressing the side button, only when the charging cable is plugged in (stays on with cable unplugged after so no issues with battery). I am able to use the side button and volume buttons to reboot so I don't think any of those are stuck and forcing it in to recovery mode.
I have opened up the phone and tried disconnecting the earpiece speaker and front sensor assembly but it doesn't make a difference. Any ideas what could be causing it and what else I could try?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I have figured out that the issue actually is being caused by the Power & Volume Button Flex Cable as the phone boots in to ios when this is disconnected. I will disassemble the phone far enough to clean out the buttons and replace the cable if that doesn't sort it.
The buttons click in fine which is why I didn't think any of them were stuck.
这个答案有帮助吗?
得分 0
2条评论:
Good find, Billbert! Be sure to take lots of pictures as you work, then you can create the very first guide to that repair available on the internet!
完成的
Just as a side note, on the iPhone X I fixed, the flash/microphone assembly also contains the power button, so it's entirely possible your phone and that one did indeed run into exactly the same problem.
完成的
添加一条评论
最有帮助的答案
Try unplugging the flash/microphone flex cable. My granddaughter's iPhone X was doing something very similar and replacing that assembly fixed the problem on her phone.
Unfortunately iFixit doesn't have a guide for that repair, but the Spanish site Nobody Calls Me Chicken (Nadie Me Llama Gallina) has just what you need. For those of us who don't speak Spanish, the Chrome browser does a good job of translating, making the guide quite usable.
Manuales / Apple iPhone 12 / Camera flash and microphone - Nadie Me Llama Gallina
Here's the part you need; you can support iFixit's repair efforts by purchasing directly from them or save a few bucks and go shopping on places like Amazon, eBay or AliExpress, among others.
iPhone 12 Flash Cable
Fix a malfunctioning flash with this replacement assembly.图片
产品
$27.99
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your help Jerry. I disconnected the flex cable for the flash but it didn't help. I have identified the issue is actually with the Power & Volume Button Flex Cable as the phone boots up when I disconnect this.
完成的
添加一条评论
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=528mgzsW...
这个答案有帮助吗?
得分 0
1条评论:
The fixes that work on Android phones are generally not helpful for iOS devices, but points for trying!
完成的
添加一条评论
添加你的答案
Billbert 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 124
总计 1,122
