跳转到主内容
A wireless, Bluetooth, gaming controller released by PowerA for Nintendo Licensing in 2018.
16 个问题 查看全部
for stick drift, why might desoldering pins help stop stick drift?
As stated in the title, why would desoldering controller pins help remove stick drift?
I was helping a friend fix his pro controller, and I tried to replace the sticks themselves. I gave up when I could not desolder the pins.
However, it turns out that was enough to remove stick drift. Hasn't had an issue for months.
I'm just not sure how that would help and wanted to brainstorm ideas. Did anyone else try something like this? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I am wondering if perhaps you've encountered the phenomenon known as a cold solder joint. This happens when not enough heat is applied during the soldering process, resulting in an incomplete weld between the two parts. Over time either movement and/or oxidation can cause the incomplete joint to separate, giving you a bad connection - which could be an open circuit or increased resistance.
It's entirely possible that your attempt at heating the solder joints added enough heat to reform the solder correctly in the cold solder joint thereby fixing the original problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lukecwolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 25
