跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Keys Not Working Correctly
A while back, my left shift key stopped working. It feels like it's slightly pressed down and won't fully bounce back up. Regardless of how many times I press the key, the shift function does not work.
Recently my left "a" "s" and "option/alt" keys are intermittently not working correctly. I need to hit the key a few times to get the letter to show up, often resulting in repeated letters: "aaaa". The "option" key is starting to act like the shift key and feels like it's not fully bouncing back up.
I haven't spilled anything on it, but my battery does need replacing. I read that the battery going bad is a possibility, but the battery isn't swollen or anything. I haven't gotten to it yet because I use my laptop almost 24/7 and don't really have the time to swop it out and have something potentially go wrong. But the keys not working is a real nuisance. I pried off the shift key to see if there was anything blocking it, just some dust, so I cleaned it, and put the key back, but it is still not working. Any ideas besides dust that could cause the keys to intermittently not work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is almost a 10 year old model, things do wear out in time, the keys that have stopped working are in the most used catagory so it is likely that a keyboard replacement is in order, there are good guides on here on how to do that yourself, just needs some patience and a little courage and anyone can do this :) The Batteries are quite easy to change. 2015's are great Macs and some would argue they are amongst the best models apple ever made, I am using one myself!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dorothy Phillips 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 98
