跳转到主内容
ROG Ally的维修和拆卸信息,这是华硕制造的一款手持游戏机。于2023年发布,型号为RC71L。
Right Bumper only registers when pushed backwards and down
Just got my ROG Ally second hand, guy said his kid used it maybe 5 hours before wanting a Switch instead so I don't believe he sold it knowing the issue.
My Right bumper only activates when pushed firmly in the center and/or it is pushed towards the back of the device and pushed down with regular force. I opened the device but couldn't see anything obvious. Just wondering if this is something I could easily fix on my own or if it's likely needing to be sent in to ASUS.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
This sounds like it warrants a bit closer inspection. You said you opened the device? Can you post some images? The bumpers are actually triggered by a button mounted to the motherboard. Although those switches are reinforced by a bracket, it's still possible it is not firmly attached to the board any longer and pressing it at certain angles still allows it to be activated, or for switch to contact the board properly.
It's a fairly common fault on shoulder buttons in general, and I have seen it commonly on Steam Decks which use asimilar mechanism (albeit no additional brace).
Video below for some context. It should be timestamped, but skip ahead to about 12:20 for shoulder button info.
I would also make sure the little nub on the bumper that activates the button is in good shape. it could be bent, or deformed. Additonally it looks like those buttons are plastic welded into the front case, so those welds could have come loose as well meaning that the button isn't in proper alignment.,
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Metrinui 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 54
总计 1,304
