跳转到主内容
Why is my MacBook Pro 2019 13" getting a black screen and no chime?
My MacBook Pro 2019 (it's a 2019 don't pay attention to the device details) 13 inch stopped working about a week ago. It has had a yellow line down the screen for awhile and I don't know if this is related. When you turn it on, you get no chime and nothing on the screen, except the yellow line which darkens and brightens.
I've tried resetting the SMC, PRAM, and I've tried disconnecting the battery with the same results. I've tried the SMC and PRAM multiple times also. What else can I try?
I'm beginning to think it is the logic board.
Thank You!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
  1. Does it react on caps lock key?
  2. What happens if you start it while holding Option key with usb stick with activity LED connected?
if you are able to find usb-c Hub with HDMI connector, try to disconnect the internal screen and start the machine with usbc-hdmi display connected. on first start, keep cmd+opt+p+r pressed. keep it pressed around a minute, then let the device run further.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mlcottle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 77
