跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
Reverse Camera now Black with safety guides - Honda HRV 2016
Pioneer DMH 2660 NEX
Putting car in reverse brings up safety guides but no camera image, just black.
I've tried everything (except the right thing) - may be the wiring of the camera cable or bypass cable? The green wires do get a little confusing. I've read every post of the same problem in other vehicles.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ellenmatthew,
Just double checking.
Have you verified that there's power getting to the rearview camera when reverse gear is selected?
Here's the wiring diagram and connector pinout for the rearview camera for your vehicle. Presumably you have an aftermarket head unit installed but the camera end would be the same, so you may have to check each of the wires from end to end between the camera connector and the headunit connection to make sure that they're connected correctly.
If the wiring is correct and if there is power available, then perhaps the camera module is faulty. If the module is faulty, according to this link the part number is 39530-T7A-003 but you may wish to verify this. If it is, search online for the part number only, to find suppliers that suit you best.
(click on image)
这个答案有帮助吗?
得分 1
1条评论:
Blond moment- I went over the 25 connectsi had to make d found I had forgotten to connect a tiny plastic clip from the maestro harness to the car harness. Rookie mistake.
Thanks!
完成的
添加一条评论
添加你的答案
Ellen Matthew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 372
