跳转到主内容
Dead p40pro+ after disconnecting battery ribbon
I tried to switch off phone which has damaged screen so I simply disconnected battery ribbon from the board. Now, after I reconnected it the phone doesn't switch on. Also after I connected mouse to the phone it doesn't get any power. Normally the LED should light up, even when phone is off. Any help?
Is it normal for battery or mobo to fail in this type of case? I mean just when the ribbon was disconnected when phone was on. I was very delicate. I'm sure I didn't break ribbon cable nor fused anything nor broke the connector/jack.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Kuba, have you tried charging the phone? Some smart phone batteries have circuitry in them to drain the battery if a connection is not detected. You can also try reseating the connector. If not you might want to look into a replacement battery.
Best of luck, BetaTech Labs Repair AU
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kuba Swiezyy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 19
