跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
SSD Won’t boot once installed only externally… HELP
SSD (Lexar SATA 6Gb) Won’t boot once installed Internally screen goes black then the prohibition sign appears but it will boot externally while the original HDD is installed anybody have a solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It’s likely this SSD is a fixed SATA III (6.0 Gbps) drive not the needed SATA II (3.0 Gbps) this system requires. While there are Auto sense drives which will drop down it’s I/O speed to match the systems. I don’t believe that’s the case here. So why does it work externally? The SATA to USB case can force the speed as the standard was updated after this system was designed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kapp God 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 73
