跳转到主内容
Samsung Tablet from December 2021. The model number is SM-X200 for the WiFi model, or SM-X205 for the LTE/4G version.
Tab A8 Screen won't turn on after replacing lcd flex cable.
Hello, I own a tab a8 and my screen became lose from the adhesive and the screen fell off and when it fell off, the Lcd flex cable ripped in half while the tablet was on.
Ive bought two different lcd flex cables and tried both and neither have worked.
the tablet screen wont turn on at all. any help is appreciated, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi, You should make sure the new cable is not torn or damaged. You can also try reseating Both ends of the cable. You should inspect the display to make sure that the connector on the display is not damaged. It is also possible that the display cable caused a short and fried the tablet.
Best of luck, BetaTech Labs Repair AU
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your response, unfortunately i've tried the things you mentioned and my tab a8 still didn't work so i guess the tablet is fried. I guess my best option would be to buy a new tablet. thank you for your help
完成的
I'm sorry that it failed. At this point my guess is motherboard is messed up.
Best of luck, BetaTech Labs AU
完成的
添加一条评论
添加你的答案
Anonymous_Bozo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 474
