No charge, Not powering on, not recognized by PC
My Samsung S21 was acting a little funny the last week until it finally went into a reboot loop for a few minutes then just straight up died. I only noticed because my Samsung watch was buzzing when it disconnected so I pulled the phone out of my pocket and saw it trying to restart. It did this several times and then refused to turn back on. It won't charge by cable, it won't connect to a PC, and it briefly showed the circle with a lightning bolt with a wireless charge but now it's not even doing that.
I tried opening it up to see if there was any moisture in it (I sometimes wipe my phones off with a damp cloth) and saw nothing. I let it sit under a fan overnight just in case, still nothing. Checked the main connections, nothing.
What should I try here first? I am already buying another phone I just need the data off of this one, but I can't even get it to connect to my PC. There is no visible water or debris in the charge port and I've tried several cables.
2条评论
Did you plug in the phone into a wall outlet?
由 EverythingAwesomeTech 完成的
Yes. Tried different chargers and everything.
由 J JJ 完成的
