跳转到主内容
The 2005 RL was also the first Honda vehicle to use the Advanced Compatibility Engineering (ACE) body structure, which has since proliferated throughout every newly introduced Honda and Acura vehicle design.
How do I rematch the smart key to the car?
The first problem was the battery drained and the car wouldn't start. The second is I changed the battery in the smartkey and all communication stopped. The green key on the cluster flashes and welcom driver no longer appears. When we try to rematch the key the message we get says no communication with ecu
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like you changed the battery in the FOB because it wasn't working. Now, with a new battery, it still isn't working.
Then you tried to repair the FOB, which you shouldn't have needed to do anyway, so it looks like the problem is in the ECU. I assume you don't have another FOB to try.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Placido Baca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 117
