跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
150 个问题 查看全部
Charger port replacement lost plate screw
While changing the charging port I lost one of the tiny 1.4 mm screws in the laptop. It’s the one that holds the plate over the port. Will this prevent the charger from working? Everything else went exactly as the guide but it didn’t fix the issue. I did confirm that it was the charging port that was preventing the computer from charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you install CoconutBattery app so you can see what’s happening? If not let’s do that and post a snapshot of the Apps main window so we can see what’s happening as well with the charger plugged in.
As far as the cable cover screw as seen in Step 5 in this guide MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement as long as you got the one screw in the plate should be OK, even still you should get a replacement screw just make sure it’s not floating inside.
这个答案有帮助吗?
得分 0
3条评论:
I guess I can’t do that since it’s got no power and I can’t boot up.
完成的
@susanlarsen - Well that sucks!
Are you sure you have a working charger and are using the correct USB-C cable for your system? If you are sure then that only leaves the battery has failed.
完成的
Thanks for taking the time to reply. It’s driving me crazy that I can’t find that little screw lol. I do believe the cable is good but will double check that first and will have to decide whether to spend the money on trying a battery replacement.
完成的
添加一条评论
添加你的答案
Susan Larsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 30
