跳转到主内容
BeagleBone Black is a model of BeagleBoard introduced in 2013
Power light on then immediately off
Checking across most capacitors (like C2) reads almost shorted so I assume a component has failed. Short appears across the whole board so I assume a main power rail short and once the power regulator sees the short on the output it shuts down. Anyone have any guesses on which component(s) may have failed. I have 2 BBB with the same exact issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
In my opinion, your BBB may have a broken power management chip or some shorted diodes. If all shorts disappeared after removing power chip, the power management chip must have a problem.
If not, other components(or both them and chip) have problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Techni Plex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 121
