跳转到主内容
2018年10月,谷歌发布的自有品牌手机Pixel的第三代产品。
105 个问题 查看全部
permanent vertical lines on display after battery replacement
I did the guide on replacing the battery of a pixel 3 with the ifixit kit.
Everything was fine after taking off the backplate, then i swapped the batterys and used 99% isopropyl alcohol to get the old battery out. After installing the new battery, the screnn showed vertical green lines.
I found multiple Questions here that found, the problem to be with the alcohol and that it would evaporate itself if you wait a while. I did so by letting it stay open during the night. The next morning, just as expected the screen was completly fine again, no lines or any other damage whatsoever.
After using the phone for half a day, the lines came back, stronger, brighter, more and diffrent colors.
I think the screen is propably broken, but I would really like to know why. What was the cause ?
Was it the force or heat of taking off the backplate? But why did it work for two day, no problem.
Was it the isopropyl alocohol ? But why did it work for half a day after having time to evaporate and why would the alcohol permanently damage the screen ?
I really hope someone can give me a bit of insight, also ideas on how to continue would be apprechiated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm not sure if this could be related, but you have to be careful when you use Isopropyl alcohol. The reason is the most Isopropyl alcohols sold in drug stores are mixed with 30% of water. This is enough to damage some sensitive electronic parts. You have to make sure that you're using 99% of alcohol concentration. When people talk about Isopropyl alcohol in their electronic repair guide, they some times neglect to mention this extremely important detail.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Screwupasitseems 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 13
