跳转到主内容
A top-loading washing machine by Fisher&Paykel.
Displays Out of Balance and then stops
Fisher and Paykel Top Loader Model: WA8560E1.
The machine stops and displays "Out of Balance" even if only a few clothes in it mostly at when Time to Go display is 27 and 10. Tried many times to reshuffle clothes in it and press "Start/Pause" button. It starts working and stops again with the same message. Kindly help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @anill31814
Here's the service manual that may help.
Go to p.14 of the manual to see all the possible causes for an out of balance error - code 03 in diagnostic test.
If a part is faulty and needs to be replaced search online for F&P WA8560E1(insert model code e.g. 92233-A or 92245-A etc) parts to find a parts list that shows the F&P part number for the part.
Then search online for the part number to find suppliers that suit you best.
Here's just one example. This is for a model/code WA8560E1 92245-A.
Be aware that even though the model number is the same if the parts list is for a machine with a different model code, then the part may not be applicable to your model. So ensure that you're looking at the correct parts list or confirm with the supplier that it is OK for your machine. The model code is found next to the model number on the product information label on the back of the machine .
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much @jayeff for your support. Regards
完成的
添加一条评论
添加你的答案
Anil L 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 32
总计 363
