跳转到主内容
加入维修社区 - 创建账户
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Replaced screen - partial black portion
I replaced a screen A2337 on a Macbook Air. The screen works but there's a weird dead pert of the screen on the right side about and inch wide from the top of the screen to the bottom. I followed the correct uninstall and install directors from ifixit. Made sure the battery was disconnected when ever I tried to reseat all connectors multiple times to see if I messed anything up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Where did you buy the display from?
Update (05/04/24)
Yeah, it probably is a low quality knock-off. Do not buy parts from that brand, or generally any in Amazon. I would probably recommend getting a screen from iFixit. Even though they may be expensive, they are high quality and reliable.
这个答案有帮助吗?
得分 0
1条评论:
GBOLE, from Amazon, had a friend recommend it to me.
完成的
添加一条评论
Sadly the display assembly has a problem 😢
Now where is the problem is the next question! The logic board to the displays T-CON board are not the issue! This cable carry’s the encoded screens data via eDP signaling. The ribbon cables from the T-CON to the LCD panel carry’s the raw column and raster data feeds.
To help make sense of what’s happening think how cloth is made, a weave of threads in an X and Y configuration. That’s the same with the data lines to set the discrete pixels. So… a set of lines from the T-CON to the LCD panel column feed it’s self have been damaged.
So could you have damaged the ribbon cables? Or is the damage deeper inside the assembly?
这个答案有帮助吗?
得分 0
4条评论:
So checked the ribbon and pins and they are fine, I put the old screen back on and it wasn't present.
完成的
@wattztech - To be clear the original screen is also showing the same issue? Yet an external monitor is fine? Which ribbon cables did you check the one from the logic board?
完成的
On the original screen the issue is not present.
完成的
@wattztech - Good! You had me worried! Time to get that replacement display assembly returned for a replacement!
完成的
添加一条评论
添加你的答案
WattzTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 257
