跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Touchscreen isn't working after standby, after reboot it works again.
So I can play what ever I want and as long as I want and it works fine, but after standby touch doesn't work. But when I reboot the touch works again.
I thought maybe software problem, so did factory reset but still the same..tried the latest update and still the same
Any clue what might be going on?
Ps: I don't have a extra gamecard reader to try
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@darthmango
Yes this is how I always reboot
But I fixed the issue. It was something completely different. I was thinking about the rcm-jig and how this probably could damage the joyconrail. So I replaced the right joyconrail and now the touchscreen works every time coming out of standby.
这个答案有帮助吗?
得分 1
添加一条评论
Try to turn it off after every use (it may be annoying to power it back on) but for most technology truning it off instead of putting it into sleep mode weirdly helps and considering after turning it off and on again helps after putting it in sleep mode especially if it hasn't been turned off in a while. Try this for about a few days and hopefully it works.
这个答案有帮助吗?
得分 0
4条评论:
Thank you for the reply Hampter.
I'll try it. Hope it'll work =D
BTW it's a v1 (unpatched) device. You'll probably understand why I don't turn it off.
完成的
@arie42291 reboot to hekate via the homebrew menu then, it'll have the same effect
完成的
@arie42291 isn't it weird that one broken piece can brick an entire peice of technology
完成的
@hampter yeah it's weird especially because it only happened after standby but worked after a reboot.
完成的
添加一条评论
添加你的答案
Arie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 73
